vertical line on left side of tv and pixelated noise all.
Hi,
I have a samsung smart tv UN40ES6100FXZC, 5 years old that just started showing a vertical line on the right side of the screen and general pixelated noise throughout the screen. This only seems to be happening on HDMI input. When I loadup the Smart Hub screen, it looks normal.
@iain not quite sure what you are referring to as pixelated noise. Post an image of what your screen looks like with your question. Use this guide Adding images to an existing question for that. It will allow us to see what you see.
by oldturkey03
Hi, Have you tried a different HDMI cable or port on the TV? What is the source of the HDMI signal? Can you connect the HDMI source to a different TV and see if the problem still exists?
by jayeff
Hi, I'll attach an image when I get home tonight.
I'm getting the same result when I plug in my PC to the HDMI port and when I plug in my receiver (it has a wallpaper that comes up when the radio is on) I have tried 2 different HDMI cables so I'm pretty convinced its a TV problem and not a source problem.
by Iain
Hi, Have you got more than 1 HDMI port on the TV to try? If so does it happen on all of them or only the one?
by jayeff
Hi, I've tried 2 HDMI ports in the back and both give the same result. Its just wierd that the picture is fine when I use the Smart Hub (for Netflix). It only seems to be an issue when I use the HDMI ports
by Iain
Show 1 more comment
