Screen is coming up with coloured lines, how do I fix it?
I have coloured lines over the screen and the display has shifted after a fall. How can i fix it cheaply?
Sounds like you need to replace your display. Unfortunately there isn't a different way to fix the issue.
If you look at the images i put on, is it just a screen replacement?
Yep! Classic broken screen. When you see the distortion on the screen focused on one point like that, its almost always the screen. When its lines going through randomly that makes for the expensive repairs :)
Follow the iFixit replacement guide and you'll be up and running in no time.
Thanks ever so much Josh. Could you give me a link to the replacement guide for the 6s. Thanks again :)
Also the screen on these lines is unresponsive and if you touch it, it doesn't work. Away from the lines does though.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 753
