Released September 25, 2015. Model A1688/A1633. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
1354 Questions View all
Screen is coming up with coloured lines, how do I fix it?
I have coloured lines over the screen and the display has shifted after a fall. How can i fix it cheaply?
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Sounds like you need to replace your display. Unfortunately there isn't a different way to fix the issue.
Score 1
Comments:
If you look at the images i put on, is it just a screen replacement?
by
Yep! Classic broken screen. When you see the distortion on the screen focused on one point like that, its almost always the screen. When its lines going through randomly that makes for the expensive repairs :)
Follow the iFixit replacement guide and you'll be up and running in no time.
by
Thanks ever so much Josh. Could you give me a link to the replacement guide for the 6s. Thanks again :)
by
Also the screen on these lines is unresponsive and if you touch it, it doesn't work. Away from the lines does though.
by
Add a comment
Add your answer
Connor Martin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 7
All Time: 146
