Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3231 Questions View all
Can you build an iPhone 4 from all oem parts?
Does anyone know if it is possible to build an iphone 4g bassically form scratch using all oem parts? I seemed to have found all parts needed, but i am unsure if the motherboard will already be softwared, or if this would have to be programmed?
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
In theory, anything's possible -- you could always restore the device from iTunes. That said, you might not even have a serial number or the thing might not power on, depending on where you get the main board from. It's probably not worth the effort.
Score 2
Comments:
+ someone always want's to pay double
by
Add a comment
Add your answer
sean will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,789
