What resistors missing in this motherboard MacBook Pro 13" 2011 late
Can i know resistors names ? I want to try to fix my macbook to work normally again. Because both usb not working and camera not working too....
Because after fixing, they are missing now... Seems good repair man was on motherboard....
https://s9.postimg.org/5muh5qcq7/resisto...
Thanks for help and answers
Update (10/21/2016)
After soldering three components back:
C9424 is a 0.47UF 10V 10% capacitor in a 0402 package
R9424 is a 22ohm 1/16W 5% resistor in a 0402 package
R9437 is a 82ohm 1/16W 5% resistor in a 0402 package
MacBook turns on again. But no 5v on MacBook. No iSight camera and usb...
Any suggestion to check ?...
Score 2
4 Comments
If you are looking for the resistor size and value, like what you need to replace them with correct one, you will need to buy a schematic. The legality of schematics is still kinda sketchy, apple doesn't want you doing board repair.
by
Where i can buy it ? How much it can cost ? Maybe it not worth to repair...
by
dariuspetrusevicius is the image from your board or somewhere else? Logicboard is a 820-2936? the orientation of two components does not look right. They should be horizontal not vertical. Did you resolder those?
by
Thanks for answers. Yes board is mine. repair main soldered them off and them put them in vertical.... Seems he made mistake and my camera stopped working too. So i need put two in horizontal and one in vertical. But what values they are ?... Because after he starter to repair, camera worked. Just USB not worked.... But after that, 5V gone too with camera....
by
Add a comment
1 Answer
Chosen Solution
dariuspetrusevicius yep your repair man definitely made a mistake. Don't use your board the way it is. Let's hope nothing else got damaged. Let me know if this image makes sense. Watch the orientation of the parts.
Score 2
13 Comments:
You are amazing, i will try order parts and solder them in right... Then give answer back. Thanks again Sir
by
You are welcome. Best of luck to you.
by
Without that three parts, can usb lose 5V and camera of macbook pro ?
by
absolutely. those parts are all part of a critical circuit and are even connecting in the display port circuit. Remember that by reversing the direction of how they were mounted, this may further created a short circuit etc.
by
I have ordered resistors and capacitor, gona replace it soon. Can macbook work without them at this moment ?
by
Show 8 more comments
Add a comment
Add your answer
DNABUG will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 968
