No signal on monitor / HDMI to VGA adaptor used
Hello. I am trying to connect my pc that has only HDMI to a monitor that has only an VGA entry with an adaptor cable HDMI to VGA, and I am getting no signal on the monitor. Any advise, please_
Thank you very much!
Add a comment
1 Answer
Chosen Solution
Hi,
Because HDMI is a digital signal and VGA is an analogue signal, you need a converter to connect between the HDMI output and the VGA input
Here are some examples. As I do not know your location you may have to source them 'closer to home'.
http://www.cablechick.com.au/cables/pass...
https://www.jaycar.com.au/hdmi-to-vga-st...
Be wary of the ones, because they are cheap, that show only a cable having different connectors at each end. (Here is an example http://www.ebay.com.au/itm/HDMI-Male-to-... . You need something to convert the signal from digital to analogue, just wiring two different types of connectors together can't do it.
Score 3
Add a comment
Add your answer
J Vidal will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 54
Past 30 Days: 270
All Time: 2,520
