Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1952 Questions View all
iPhone syncs to computer but won't charge - What do I replace?
I accidentally slept on my iPhone last night and broke some things. :-(
The display backlight is gone so I know I'll be replacing the display assembly.
The other issue is that the iPhone no longer charges when plugged in, either to a computer or a wall adapter. This has been tested with multiple cables.
It still syncs fine with the computer, it just doesn't pull any power.
What do I have to replace to make it work?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Sounds like you need a new battery too (if not, then you have to replace the whole logic board, so I'd try the battery first).
Add a comment
Add your answer
CStigler will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,729
