Can the LCD be replaced?
Is it possible to remove the bezel around the screen to access the LCD? If it is glued on, would a similar heat-gun method as needed for the recent Macbook Pros work?
to use a heat gun... see How to Replace the Macbook Air Hinges and LCD - heat can deform the rubber trim.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
Thanks! Sorry, should have checked earlier revisions of the Air line for the answer before asking.
lutris you can remove the bezel and change the led from that . i have also changed the led . see the link :
http://www.youtube.com/watch?v=eHNtnvzfS...
be patient thnx
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 5,500
2 Comments
Can anyone tell me what the part number is for the LCD panel. I'm trying to find a exact replacement.
by weidyc
weidyc, it would work better for you if you click on the link on the right side of this page "ask a question" and give as much detail as possible. I also believe that the apple guru's always ask for the serial numbers...anyhow give it a try and I am certain you will get a quick response. Good Luck
by oldturkey03
