The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3766 Questions View all
Replacement screen not fitting fully, loose at top corner.
Hi,
I recently replaced my screen and it wont fully fit back into place seen below as its a bit loose.
https://s12.postimg.org/knoaz1jvh/DSC015...
Also the new screen is having trouble with darker colours as seen below., First pic is the camera facing down but the second pic the screen is ok with lighter colours. I've tried disconnecting the screen cables again but still the same issue.
https://s10.postimg.org/m1rnxa2ah/DSC015...
https://s21.postimg.org/6j8bdh9xj/DSC015...
Kind regards,
Binod
Add a comment
1 Answer
Chosen Solution
For the first issue: you slide the top of the phone in first. Push it towards the top of the phone, then push down and work your way to the home button.
The second issue looks like a bad LCD, probably when it was misaligned, it damaged the LCD.
Score 1
Add a comment
Add your answer
binod5098 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 38
