Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
275 Questions View all
How to replace the stock hard drive with apple certified SSHD?
Hello,
thanks for a really good resource of info about apple products. I found this iMac Intel 27" EMC 2429 Hard Drive Replacement
My question is simple. I don't want to heat my iMac and hear it roaring. So if I buy this seagate https://eshop.macsales.com/item/Seagate/...
and follow your guide is it gonna work smoothly ?
Thanks
Comments:
FYI - Both drives are Seagate 3.5" SSHD's
by
Add a comment
1 Answer
Chosen Solution
For either you'll need this: OWC In-line Digital Thermal Sensor for iMac 2011 Hard Drive Upgrade. I don't recommend using software over-rides as time has proven they don't work as well and if misused damage your system.
Score 1
Comments:
Dan hi, I found out that I have the mid-2010 iMac. It means I need the termal sensor cable for 2010, right ? like that one https://eshop.macsales.com/item/OWC/DIDI...
by
Correct! You'll need the 2010 version.
I also corrected your posting so it now reflects the correct model. Here's the IFIXIT guide you'll need to follow: iMac Intel 27" EMC 2390 Hard Drive Replacement
by
replaced SSHD, works good so far. btw what is the "optimal" Mac OS for iMac 2010 ?
by
I would go with the latest the system can support - macOS Sierra 10.12.x
by
Add a comment
Add your answer
Dan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 75
