Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2911 Questions View all
Why is my phone not turning on, but vibrates when charged?
My phone was dropped and the screen was cracked and black. I replaced the screen myself, but when I tried to power it up, it would not turn on. I tried the force restart, but to no avail. Here's the wrench: when I plug in the phone, the phone will buzz as if being charged and still will not show anything on the display. Thank you so much for the help.
Comments:
I meant to add "How do I fix this?"
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Double check the LCD and touch screen ribbon cables to see if they are plugged in properly.
Make sure to disconnect battery first before doing so.
Improper installation (in result may end up with damaged ribbon cables) can be the reason why the screen isn't showing display.
Score 2
Add a comment
Add your answer
vposey will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 25
