What is the max carry load for a 2015 Chevy Spark
What is the maximum load a 2015 Chevy Spark can hold (For example, what could the combined weight of passengers PLUS cargo be)
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Liz Pagel looks like the Gross Weight Limit is around 3014 lbs OR 1367 kg
Update (10/13/2016)
Curb weight is 2246lbs / 1019kg – manual (LS model) and 2312lbs/ 1049kg – CVT (LT model). So if your model is a LT model then gross weight-curb weight (3014-2312) shows your total load can be no more than 702 lbs
Score 3
Comments:
Thank you, but I am looking specifically for how much weight can be inside of the vehicle (I.e. If there were three 200 lb adult passengers +cargo...)
by
Well Liz, simple math can help you. If you have 3 people in the vehicle, that's 600 lbs (200 lbs x 3 people). You then take that away from 3014 lbs and you have 2414 lbs left (2414 lbs - 3014 lbs). I'm not sure what kind of answer you're looking for. If the max weight is 3014 lbs, you then need to calculate it on your own.
by
Add a comment
Add your answer
Liz Pagel will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 94
All Time: 1,266
