Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2921 Questions View all
Charging iPhone 4s problem?
My iphone 4s will only charge sometimes. I have to plug it in and out a bunch of times until it finally charges.
but when my phone shuts down and I plug it in once it will charge until it turns on and then the battery is not charging at all once the lock screen loads up?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
If you haven't already, firstly try another charging cable and / or wall adapter.
Those are all signs of a bad charging port. Replacing it should do the trick.
Where you can buy the part:
iPhone 4S Dock Connector
Guide to replace the part:
iPhone 4S Dock Connector Replacement
iPhone 4S Dock Connector Image
Product
$19.99
Score 3
Add a comment
if you're able to check the voltage of the battery would be helpful to know also. It could be the battery either needs a boost or is defective.
Add a comment
Add your answer
Steph will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 50
