The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3506 Questions View all
Wifi button greyed out after Touch IC repair
So we had a customer who's IPhone 5s had (inexplicably) stopped touch.
First thought was a faulty LCD but when changed, still would not touch. So we sent away to technician to look at the IC which he fixed and touch came back. We gave the phone back to customer and 2 days later he calls and says that he can't turn on wifi.
He claims that wifi was working prior to repair (even though the touch wasn't working so couldn't have checked anything) he said that his Apple Watch was connected to the iPhone hence why he knows the wifi was working. He said he tried resetting network settings and restoring it through iTunes to no avail.
I took it back to my technician who denies he's at fault. But He has looked at it, made sure antenna is connected, changed the wifi flex cable, even changed the Wifi IC but no luck.
He says the only other possibility is the U2 IC chip but this could wipe the phone data.
Does anyone have an opinion on this please?
Score 1
Comments:
**UPDATE**
The phone is really playing up. I put my sim inside to update the date and time as innoticed it was day and half behind. Now there's heat coming out of the main A7 chip area. The camera is behaving erratically, the phone antenna signal jumps around.
I'm calling this phone a write-off
Whatever's caused the touch IC to malfunction, I think is causing all these other problems including dead wifi...
by
Add a comment
Chosen Solution
To repair touch, you have to work on the board right next to the Wi-Fi chip.
He probably reflowed and possibly replaced one of the touch ICs, and by this exposing the Wi-Fi chip to heat. And Wi-Fi chips are notoriously sensitive to heat and may stop working if exposed to lots of it.
Another possibility is that a drop caused touch to stop and that same drop caused Wi-Fi to stop by causing micro fractures under the touch IC and the Wi-Fi chip. But you could only tell after restoring touch .
Finally, "U2" has absolutely nothing to do with it and besides replacing it does not cause data to be wiped. This is complete nonsense. It is like saying if I replace your fuel pump I may be able to fix your car radio, but your tires may end up flat.
Score 2
Comments:
Thank you for the clarification Rany. My technician told me that he tried to replace the wifi chip and still no response. Should I get a second opinion? Is it easy to change the wifi chip without further complications?
by
It all depends on skill and preparation. I am not skilled enough in Wi-Fi chip replacement. I already attempted it without further complications, but I took my time and some precautions.
by
Add a comment
Sometimes if you let the phone sit wifi comes back. Its not the wifi chip itself but rather caps that have changed temperature during heating. Many times letting the phone sit and letting the caps come back to normal functioning temp will resolve wifi issue.
Add a comment
Add your answer
Amir A will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 41
All Time: 599
