My phone does not want to Charge
My Lenovo A6000 phone says there is a problem with the connector.
med, try a different charger, if still will not charge could be a bad connector or battery.
medfarouk63 if you are sure about the connector then you will have to disassemble your phone and check the solder on the back of it. Make sure that it is still properly connected and works properly when the adapter is plugged in. Check on TP5 and ground for 5V.
The connector is soldered so you will have to unsolder it to repalce it. Not an easy task unless you have the right tools and practice with that type of repair.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 96
