Released June 2012, Model A1278. Intel processor with Turbo Boost, Up to 512 MB DDR5 Video RAM
816 Questions View all
DDR3L or normal DDR3?
Hi! Do I need normal DDR3 or the lower voltage DDR3L RAM for my mid-2012 Macbook Pro? Everyone says something different. Thanks in advance!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Best answer here is to use what Apple documents: MacBook Pro: How to remove or install memory. Here's what Apple states:
MacBook Pro (13-inch, mid 2012)
  • Number of memory slots 2
  • Base memory 4 GB
  • Maximum memory 8 GB
Memory card specifications:
  • Double Data Rate Small Outline Dual Inline Memory Module (DDR3) format
    • 67.6mm x 30mm (1.18 inch)
    • 2 GB or 4 GB
    • 204-pin
    • PC3-12800 DDR3 1600 MHz type RAM
Additional notes: For best performance, fill both memory slots, installing an equal memory module in each slot.
I should point out this listing is a bit dated as this series can support 8 GB modules so you can go up to 16 GB of RAM.
Score 2
Comments:
Thansk! So just to be clear, this is the 1.5v 'normal' DDR3? :)
by
DDR3L is a dual voltage capable memory DIMM, which supports operation at both 1.5V and 1.35V. DDR3L is also pin-compatible with DDR3.
DDR3 is a single voltage capable memory DIMM, which supports 1.5V operation only.
Basically you can use either but the older DDR3 is cheaper.
by
Thanks a lot!
by
Add a comment
Add your answer
Tim will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 63
Past 30 Days: 236
All Time: 3,168
