Why is my screen overlightening in some areas
my iphone over brightness in some areas of my screen
Its a bad screen. More specifically, it looks like a bad backlight. If you did the repair yourself, you can replace the backlight pretty easily. Otherwise, if you paid someone to fix it, they should swap the screen out for you.
That kind of damage usually comes from someone trying to force the screen in, cracking the backlight. These displays are getting thinner and more delicate, can't use much force at all with them now.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 65
3 Comments
[image|907619]
This is how it looks
by Sandesh Silwal
Has the screen been replaced before or phone been in contact with liquid?
That is either liquid has gone into the screen and seeped into the backlight area which is located under the LCD (liquid crystal display) causing those uneven colored marks in the areas where the liquid has set to.
Maybe it could be a bad quality replacement screen instead? but that's highly unlikely.
by Ben
No screen was not replaced but it was repaired
by Sandesh Silwal
