First iteration of JBL's Pulse line of wireless, bluetooth speakers released in 2013. Unique to this speaker is its light array that "pulses" in rhythm with your music.
13 Questions View all
How do I restore my JBL Pulse to factory settings?
I am trying to connect my Pulse speaker to my phone JBL app. I can play music through the speaker but not connect to the app so I was wondering how to restore the speaker to factory settings.
Score 1
Add a comment
Chosen Solution
To reset the unit to factory setting:
1. Power on the unit by pressing the on/off button for about one second.
2. Press the "Vol - " button and the "Bluetooth" button together for more than 7
seconds.
3. The unit will display Red, Green, Blue light and go into power off stage, but with the
on/off light and the light symbol lighted up.
4. The unit is now reset to factory settings.
5. Switch the Pulse OFF by pressing the on/off button for about one second.
6. You can now turn your device back on and it will be reset to factory settings.
Score 4
Comments:
I did I followed your instructions and now it's flashing white and won't respond in any way
by
Is anybody out there my speaker won't respond after I did the factory reset all it will do is Flash White and won't shut off or turn on or do anything
by
I'm you, i did the factory reset then all flash light, all botton can not do anything. Please help.
by
Mine did the same thing. Cannot get it to do anything now. Help!?!?
by
This fixed my unit. I did have to connect the charger first to get it to power on though.
by
Show 1 more comment
Add a comment
Hello Ryan, do you maybe know how to reset JBL Pulse 2 to factory settings? I can't find that information anywhere... thanks
Score 2
Add a comment
Hello Everyone,
My JBL Pulse 2 one day was unable to connect to Bluetooth devices and turned off randomly with a full charge. I tried the "Vol - " button and the "Bluetooth" workflow suggested above with no luck. I then turned to JBL support and they provided me with the follow steps that worked.
  1. Power on the JBL Pulse 2
  2. For 2 seconds, press and hold the "Volume +" and "Play" buttons
  3. The JBL Pulse will power off, and is now reset
Please let me know if anyone else has similar results by using the below "was this answer helpful?" section. It doesn't seem like this reset workflow is not documented anywhere else.
Score 2
Add a comment
The reset, by pressing " Vol - " and "Power Button" at same time, worked well and now it is fixed, now I am able to connect my JBL (2013 model) in my iPhone 5s and iPhone 7, tks for the tip!
Score 1
Comments:
Tiene muy buen volumen y trabajo bien x un tiempo ahora ya no carga! No trabaja y luego no kiere su propio plug! Ummm.... Ya no hacen cosas buenas ni duraderas! Y ni quien le ayude! Quedo peor después de querer reiniciarlo
by
Great! The resseting with Vol(-) and power button works! Now I can pair my JBL E25BT
by
Add a comment
I have problem with my JBL e25Bt bluetooth earphone. Can connect to my iphone. If idle, after few seconds disconnects, so in order not to disconnect, i continue play music. Anybody can help?
Comments:
the same problem
by
the same problem here...
by
I Also have same problem, I tried with multiple combinations of buttons not my JBL e25Bt bluetooth earphone is not detected by any phone or tablet.
Please help me.
by
Add a comment
man i have clone jbl headphones.. i was using them.. suddenly they disconnected but the blue light was still on ( the blue light is on when u are connected ) .. then i put it to charging and left it there.. now when i take it off charging it wont turn on.. btw it is still charging
Add a comment
Add your answer
Ryan will be eternally grateful.
Past 24 Hours: 164
Past 7 Days: 1,106
Past 30 Days: 4,920
All Time: 67,491
