Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
196 Questions View all
Replacing SATA HDD to SSD for my 27 inch iMac
Hello, people.
I am from India and I have a 27 inch iMac late 2012 EMC 2546.
I purchased Samsung SSD 850 Pro and I am looking to replace the internal SATA hard drive that came with the system. I approached the apple service guys and they said they will do it for a nominal cost but I have to provide them all the necessary components.
I have a few queries with regard to this.
1. Going through all the posts in the forum, I understood I need an 2.5 to 3.5 HDD adapter. I am confused in selecting one. Could someone please give me a few options?
2. If I am changing the hard drive, should I be getting thermal sensor cable? What is the use of it? I just read that for MacOS El Capitan and Sierra, you wouldn't need the sensor cable.
If I am missing something apart from these two, please guide me. Thanks in advance.
Regards.
Add a comment
Chosen Solution
Here's the guide for replacing it:
iMac Intel 27" EMC 2546 Hard Drive Replacement
Here's what you need for the temperature sensor issue:
https://eshop.macsales.com/item/OWC/DIDI...
Here's the caddy you will need:
https://eshop.macsales.com/item/OWC/SSD2...
If you want to add an SSD flash drive here's how that's done:
https://eshop.macsales.com/item/OWC/SSDI...
Installation videos are on this page.
Score 3
Comments:
@mayer - The SSD vid you posted is for the PCIe blade drive not the SATA HD connection.
Here's the correct vid: iMac 27-Inch Late 2013 HD Install Video While its for a newer model its the same process and you're using a SSD vs HD.
by
@danj I know, see the sentence before I gave the link
by
@mayer - I think he wanted to swap out his current HD for a 2.5" SSD Vs digging deep into the system to put the blade SSD in.
by
@danj just wanted to let him know there were options ;-)
by
@mayer - No worries here, just keeping you honest ;-}
by
Add a comment
2. The sensor cable measures the temperature of the HDD. One fan in the Imac is only for cooling the HDD. If unplug the sensor the fan will spin at 100% (very annoying). Some SSD´s work with apple sensor some not. But you can also unplug the fan.
1. You can use any rack 3.5 to 2.5 for an iMac. They all fit.
Comments:
How do I know if the SSD I have works with Apple sensor?
by
I have no options for 3.5 to 2.5 racks in India. So I have to be specific in getting one. If you could give me some links, that would be helpful.
by
Did you look at the second link I gave? You can probably make one out of a tin can and some tin snips and a drill. Or get an old 3.5" hard drive, gut it, drill some holes and make one.
by
Add a comment
Add your answer
Fahad Mohammed will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 151
All Time: 988
