After a fall, the phone only works with the broken part (LCD)
Hi guys, it's the second time that happens this strange thing when i work with fallen iPhone 5C. The phone only works with the broken part (lcd with vertical stripes, touch unresponsive etc.) when i try with a new screen, it never turns on, just the backlight when i try to replace it after i have turn it on with the broken screen and replaced with new with the phone turned on.
it's possible that after the fall, the motherboard and the screen will break in a complementary way?
which component should I check?
Thanks
You most likely got a faulty replacement LCD.
LCD only showing black light display with no image display usually means a bad connection between the LCD display and the LCD connector on the logic board.
Might want to check for any dust or lint on the LCD ribbon cable from the new screen and any signs of damage on the cables.
Edit: And yeah always disconnect battery first before unplugging or plugging in any cables.
by Ben
