My car cooling fan wount come onmy car run hot
my 2005 equinox cooling fan wount come on my equinox runs hot so iv changed the thirostat it still runs hot
Hi there. Did you check to make sure that your fan assembly is working? May be wire it directly to the battery to test it out to make sure that it is working. Also I believe that your model has a Radiator fan relay. You might want to replace that as well. I furthermore would check the temperature sensor switch for the fans. Just my 2cents and hope you figure it out. You don't want to drive around with a vehicle that tends to overheat since that will result in a costly repair. Good luck.
good answer +
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 3,438
