CDMA version of the fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. 16 or 32 GB / Model A1349 / CDMA compatibility.
419 Questions View all
Can't get top right corner screw back in.
I took apart my iphone 4 and, as expected, had trouble removing the top right screw (near the audio jack). Now that I am trying to reassemble, I CAN NOT get the screw back in. I have been working on it for an hour.
I am using the tool kit from ifixit and the screw driver hand is too thick to be able to get a direct line on the screw. I need some advice on how to proceed.
1. Is their a screw driver with a longer thinner shaft that might work?
2. What happens if I leave the screw out altogether? (I did try that but the reassembled phone is unresponsive.
Any other ideas?
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi !
As long as this screw is a contact screw, there's no surprise about your phone not responding once reassembled.
I suggest that you use different screwdrivers, not being able to give you an accurate reference as long as I no longer own an iPhone 4. If you still can't manage to screw it or that the head is a bit damaged, some tools sold f.e. at iFixit may help you. I personally use this one for damaged screws.
Screw Extracting Pliers Image
Product
$19.99
Score 1
Comments:
The screw head is still undamaged. I just can't get the screw driver and driver head alligned.
by
Have you tried with a flat one ?
by
Add a comment
Add your answer
A S Koski will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 17
