Whirlpool dishwasher Flashing "clean" button
I started my dishwasher as usual but this time it did not finish the dishes.
The button "clean" is flashing constantly and i have tried to pull out the cord to reset, but no luck. Any suggestions what to do?
There is no water in the machine so it seems to have empty it.
1 Comment
Had same problem: reset it by: open door then Pressing the heated, normal, heated, normal, watch all lights on, then close door. Now works as normal.
by
Add a comment
1 Answer
Chosen Solution
Your heating element has shorted out:
https://www.youtube.com/watch?v=wJsPNvtu...
Please give your exact model number so I can get you to the correct part.
Score 3
5 Comments:
The model no is GU2548xtps3
thank you in advance
sara
by
Thank you!
The last time it worked it also had a strange sound, "humming"
by
Let's see if that issue is still present after it's fixed.
by
Press NORMAL WASH then HEATED DRY 3 times to reset.
by
Add a comment
Add your answer
Sara will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 118
All Time: 9,023
