Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
Why won't my iPhone 4s charge
After replacing the battery in my 4s, the phone turned back on, I plugged in the power and the phone dinged and showed the lighting bolt up by the battery (it did not do that before the battery replacement), however is not charging.
I saw another post suggesting that the doc connector needs to be replaced, prior to the original battery failing, I never had a issues and made sure the dock connector was regularly cleaned.
1 Comment:
It might be even only the charging dock that needs replacing instead of the battery.
by
Add a comment
1 Answer
have you tried a different cable because you might have more then one problem since the phone is recognizing that you have it plugged up to something it could be a faulty cable. possibility of that is slim but it is worth a try in my opinion
Add a comment
Add your answer
Benjamin Harper will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 28
