Repair guides and support for LED, LCD, HD and other Vizio TVs.
315 Questions View all
Repair Cracked Vizio M55-C2
I got a Vizio M55-C2 and it has a crack screen. I was wondering is it possible to fix the screen or get it repaired?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
@mizterkewl if the LCD panel is broken, then there is no way to fix it. It will have to be replaced. Here comes the bad part. The panel will most likely cost you more than a new TV, if you can even find it. Remove the back of your TV and check the manufacturer and model of the panel ( same model TV's may use different model LCD). With those numbers, see what an online search reveals.
You could try to find your model TV that is broken, other than the LCD, and than harvest the LCD from that.
Score 2
Add a comment
Add your answer
Peter Pan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 39
All Time: 281
