Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3239 Questions View all
Has anyone replace there metal iPhone Frame?
I recently drop my iphone 4 and now the metal rim around the phone is dented. I purchased a replacement mid frame on ebay. But wanted to know how hard is it to replace it. I've have worked on iphone before such as replacing my broken digitizer on my last Iphone 3GS.
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
It's pretty tedious. You can remove the front and back panels with minimal technical difficulties. The trouble will be removing the ribbon cables, buttons and the rest of the innards without damaging anything. The ribbon cables are extremely delicate. I ripped one while removing the cable that connects to the power button. This phone is far more complicated that the 3G or 3GS. The components are much harder to remove much less put back into place.
With all that being said, it can be done if you devote plenty of time to the project. You'll also need to be extremely careful while working to remove the ribbon cables. Placing the components back into the new frame will take patience.
Add a comment
Add your answer
Ricky will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,118
