Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Why is my phone vibrating every few seconds, but black screen?
I dropped my phone in water then left it in rice for a few days. After when I plugged it in the screen turned on for a few seconds then off. When I tried another battery the phone vibrated every few seconds when I plugged it in.
Add a comment
Chosen Solution
Hi,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
Rice is good to eat but it does nothing to fix the problem of corrosion
First you need to remove the battery as soon as possible from the phone
Here is a link to the Ifixit guide on how to replace the battery and also the LCD screen which should give you reasonable access to the phone's components.
iPhone 5s
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water.
Here is a link that in general, describes the process.
Electronics Water Damage
You will probably have to replace the battery as it is very hard to recover a battery from water damage.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
If this process seems too daunting, take your phone to a reputable, professional phone repair service and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Score 5
Add a comment
Usually a blank screen with the phone vibrating every few seconds is a bad LCD, so you will,need to replace the screen. But make sure you follow the steps in the first answer too.
Score 2
Add a comment
Add your answer
Justin Aliolli will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 700
