Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
iPhone dead and will not charge
So I dropped my iPhone 6 Plus and the screen smashed but still worked for a couple of seconds, but I replaced the screen and now the phone won't even turn on or even go into recovery. I got iTunes error 4005 when I put a new battery inside it but all it did was heat up the area where the A8 chip was . Help many thanks
Score 2
Add a comment
Heating is not a symptom of a charge port.
Its almost always a fuse/filter that got knocked off. Part of what the charging system of the phone does is tell the phone when the battery is dead and in return, the phone kicks more juice to the battery. When part of that system is broken, the phone will throw full current to the battery. This makes the battery get very hot and it can even explode.
Its a relatively cheap fix, however it does require micro soldering skills and equipment.
1 Comment:
Battery doesn't heat up, the area where the A8 chip gets hot
by
Add a comment
try to change the charging port
Score -1
1 Comment:
I've already changed the charging port, it's got a new battery
by
Add a comment
Add your answer
Chris Hollands will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 202
