A mini tablet computer designed by Blackberry and manufactured by Quanta Computer in 2011. Model number RDJ21WW.
35 Questions View all
Charger receptacle problem - unit can't charge
It appears that when I connect the charger cord the juice doesn't flow to the battery. The battery icon doesn't indicate that the connection is occurring and the cord end doesn't fit properly any longer in the receptacle. Help
Score 1
Add a comment
1 Answer
It may just be that your outlet is not working. Here are 2 videos that explain how to reset gfi outlets and breakers. It is very easy to do. Tap on or click on the blue links to see the videos. If this is the problem you will be able to do it easily. I hope this helps. Good luck!
https://m.youtube.com/watch?v=trLeLJdMWW...
https://m.youtube.com/watch?v=OUR0GBrDmS...
1 Comment:
I tried t charge in many different outlets which all worked for other items, so I'm still unable to charge the unit. Thanks for your answer anyway
by
Add a comment
Add your answer
Jb will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 549
