Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Wifi / bluetooth greyed out iPhone 6
Hi , one of my Iphones wifi greyed out and i have done all the guides on the net :-) i have also replaced a new Wifi/Gps modul and the wifi flex cabel but still greyes out. If i open the screen and removing the battery connector and on again the wifi works a few hours before it greyes out again . Someone have a solution :-) ? Could it be the Wifi chip modul that is broken ? If so , what tools do i need to assemble a new WiFi chip ?
Score 4
Add a comment
Chosen Solution
Of course it's the chip. You can't fix a greyed out wifi with a new antenna, its like replacing the tires when your car won't start.
Score 3
8 Comments:
Thanks for answer.. is it possible to replace a new chip and how to do it :-) ?
by
If you need to ask, you should not do it. Go find a board repair professional
by
Maybe i will do that, thanks :-)
by
Boi u rude
by
Tom chai a dickhead a little bit
by
Show 3 more comments
Add a comment
I had the similar issue with GPS not being accurate on an iPhone 6. Replaced wifi antenna and hey presto fixed. This is cheap enough option to try.
On a side note, there are some techs on here that are just down right rude. Get a grip please, not everyone is a pcb genius like you.
Score 2
1 Comment:
Plus he's wrong - it's really not always the chip. Just most of the time ⏲️ 🙃
by
Add a comment
My WiFi was greyed out and my Bluetooth was also not working on my iPhone 6 so I replaced the WiFi antenna flex cable and then my WiFi and Bluetooth both started working.
This seems to be a pretty common problem but nearly all of the youtube videos and websites are rubbish.
iPhone 6 Antenna Flex Cable Replacement
Score 1
1 Comment:
I'm still debating if it would be the iPhone 6 Logic Board Antenna Flex Cable or the iPhone 6 Wi-Fi Antenna would do the fit - my iphone 6 had the greyed out wifi icon (no wifi) and while the Bluetooth icon can be switch on/off, there is no Bluetooth connection even its on.
by
Add a comment
​Hi !
I have the same problem with my iPhone 6 and more to that. For sure Ive tried hardware restart (almighty 10 secs of two-button press), syncing with iTunes and updating firmware but the most annoying is to be limited with cellular data. But as I said, there is more: After I realized that WiFi switch grayed out, I also realized that following functions started not to work either.
_____
-Bluetooth: does not turn on. dots keep spinning.
-Location Services: iPhone cannot locate itself.
-Date and time progression: This is the most interesting! iPhone clock for indicating the time does not change. it stays at the last time when it is manually set. Which causes that all the pictures taken and all incoming text messages are tagged with the same time are again sorted wrong.
-Display Rotation: Display does not rotate when iPhone is held portrait or landscape.
-Vibrate on silent: iPhone only vibrates when it is not muted.
_____
I've listed all the items as I figured up to now. If I observe any thing more I'll post for sure.
Since it happened after warranty period, authorized Apple repair shops proposed swapping with a brand new iPhone 6 for $370
I did not see anyone has ever faced all those problems at the same time. I desperately search for some reasonable explanation.
4 Comments:
almost all same-- wifi grayed out, blue tooth icon spinning- happened the morning I did new ios update, that I had neglected to do for awhile-- not sure if it didn't occur before the upgrade...only lets me use cellular data and did hard reset-many times and also went into general and did the reset as well; my screen is cracked and this did happen to me in July 2016 as well -- still searching for answers- just on the phone with apple for an hour doing an itunes reset i guess -- pretty frustrating, need to go to the apple store tomorrow:(
by
sounds like you guys have some sort o liquid damage. .. the first letter in lcd is L which stands for liquid...
by
This is basically exactly what is happening to me! Did you end up getting it fixed? And if so what went wrong?
by
Hotspot also does not work
by
Add a comment
Hi,
For me it ended up buying a new iphone
Add a comment
Hi,
I had the same issue but I found a local iphone repair shop and they fixed in less than an hour. They also handle online repair at www.mmstore.be
1 Comment:
How much did it cost?
by
Add a comment
I am facing the same situation.. wifi greyed out and Bluetooth keeps on rotating, vibration is no more.. please provide a solution if anyone know
Add a comment
Hello everyone,
I have the same problem after dropping my iPhone 6s in a lake.
After drying it for a few weeks everything works again except the Wifi and BT. I have noticed that it does work when the phone is cool. But as soon as it gets hot the Wifi gets grayed out and BT gets the circling circle.
I’ve already bought a new iPhone but I still want to repair the old one. To change the Wifi-unit costs a lot but now I am thinking maybe it could be the antenna?
Any thoughts?
Regards
Johan
1 Comment:
You phone is knackered, almost sure you have some serious board level damage. Sell it for spares
by
Add a comment
Add your answer
B Tobiassen will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 24
All Time: 67,494
