Broken home button / fingerpr. scanner iPhone 6 after replacement
Hi, i have replaced a new lcd screen to the front metal plate on my Iphone 6 , but unfortunately i damaged some of the small little plugs on the connector on the home button when i loosened it. So my question is , is it possible to loosen the broken connector on the home button and buy a new contact so the fingerprint scanner can function again. Someone who has such a guide to refer to ?
Which part of the home button connector was damaged?
The one on the board?
The one along the backplate?
The tiny piece that goes from the home button?
Please answer and I can help more.
by Josh W
Hi , its the connector on the home button that secured to the connector from the back flex cabel from the metal plate.
by B Tobiassen
ugggh....that's the worst one!
You can easily replace it, but your fingerprint scanner will no longer work :(
by Josh W
Ok, than i dont think i will try do it , thanks :-)
by B Tobiassen
