The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
4090 Questions View all
Replace it with 16GB To 32GB logic board
Hello Ifixit.
i Have 2 Iphone 5s
(Gold- M A1457) 16-GB
(SILVER-M A1530)32-GB
1.Can i Replace it with 16GB To 32GB logic board ? (Need Help)
2.home button Touch ID function will work or Not after replacing logic board ?
Add a comment
Chosen Solution
If you transfer the logic board and Touch ID cable together, it should work. However, based on the colors of your phones, if you put the 32 GB board in the gold phone, you'd have to take the silver Touch ID sensor with it, which would create a mismatch. If you want to buy another 32 GB logic board to replace the 16 GB logic board, you won't be able to keep Touch ID functionality.
Score 2
Comments:
I belive both sensors are white. Only the rim around the sensor is colored. Only in the case of the space gray is the sensor black
by
Add a comment
Swap the home button over either the logic board and you will be fine.
Add a comment
Add your answer
Kpo Nestle will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 1,579
