FPC connector touch screen digitizer
hi if the black little plastics alongside the fpc connector for iphone 5s happens to wear out , does it affect the touch screen display in some way ???
Plastic worn out can affect the connection to the digitizer / touch screen cable.
As long as all the gold connection points connect fine to the ribbon cable then it's fine for now.
Otherwise the fpc connector would need to be replaced.
hi when i press the home button of the iphone 5s like double click it the lower part of the screen above the home button seems to move the liquid inside the screen when it's being pressed each time i use the home button although no problem with the sceeen currently , does it affect the screen later on ?
That's the pressure mark when you apply pressure to the screen, usually happens on lower-quality screens. It shouldn't affect the screen later on.
okay yeah it's a low quality lcd i got from china and i don't wanna open the phone to readjust the home button because if you do take out the lcd from the motherboard and put it back even after correct fixing on the motherboard ghost clicking starts when you on the phone and i don't want that to happen again
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,364
2 Comments
They don't really wear out. The worst usually is physical damage.
by Ben
yes physical damage , does it affect the touch screen i mean the black little plastics at the sides the metallic pins are still there but the plastic worn out from changing screen everytime
by Bashir Abubakar
