Why doesn't my phone charge properly?
My phone won't charge unless it's turned off
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
Hi,
What are the specifications of the charger that you are using? It should be written/stamped on it. Look for output values, especially the mAH or A rating.
If you are charging the phone using a PC's USB port, be aware the while it can charge the phone it cannot both run the phone and charge it at the same time, as it only can supply 500mA (0.5A) of current.
To prove whether the first charger is faulty or not (If you are using a wall outlet charger), if possible try another compatible phone charger (with a rated output of not less than 700mA (0.7A) and see if it can run the phone as well as charge it,
Also do you have the GPS feature and WiFi feature enabled? If so, unless you need them, disable them as they both use a lot of power
Score 3
Add a comment
Add your answer
shinnamber will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 135
