Can the charging unit be repaired?
I can no longer recharge the unit, any ideas?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Hi,
Have you checked that the contacts on the watch and the charging unit are clean and shiny?
Have you tried connecting the charging unit to a different USB port on your PC?
Can you access the watch when you connect it to a PC?
If the answer to all the above is yes then perhaps the problem is not with the charging unit but with the rechargeable battery in the watch. Even rechargeable batteries have a life span.
This is a quote from the manufacturer regarding battery problems and your watch:
Under the vast majority of circumstances, the batteries used in our GPS Watches will provide years of trouble free use, and will not need to be changed. The warranty on the GPS watch will be void if the consumer tries to change the battery. If you feel that your battery is going bad, please contact Bushnell Customer Service at customersupport@bushnell.com.
Score 2
Add a comment
Add your answer
Clive will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 49
