I cant get it to power on after a power outage
TV won't power on with remote or cable after power outage. It is plugged into a surge protector. I've unplugged it, and plugged it into a different outlet as well.
Comments:
I have had this problem before took the back off found nothing damaged, replaced back TV worked.
Just read that a TV protection device in the TV takes 2-3 days to reset it's self.
Took power cord out of wall socket. Used screwdriver to short phase to earth for 5sec and neutral to earth for 5 sec. Theory discharge the protection device.
Plug TV back in walla all works OK.
David Nairn
+64-21631177
by
Please explain short phasing
by
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
1 Answer
Chosen Solution
Hi,
What is the model number of your TV?
Remove the power from the TV, take of the back cover and visually inspect for any sign of damage e.g. burn marks etc. If there are take close up pictures of the affected parts and post them here Adding images to an existing question
Hopefully someone here will be able to help you when they can see what you can see.
Also since your TV has most probably been affected by a power surge due to the outage or restoration (who knows), no doubt the surge protector will also be affected. Unfortunately a lot of surge protectors give no indication that they have also failed, (doing what they are supposed to do, i.e. sacrificing themselves to save the equipment connected to it). Even if they have a power indicator light showing it is no indication that they are still providing protection against power surges.
I suggest that you environmentally dispose of it as they are irreparable and get a new one (or verify with the manufacturer of the surge protector whether it would still be functioning properly). The best that can be hoped for is that it minimized the effect of the surge on your TV.
Score 1
Add a comment
Add your answer
Reyavonna Talley will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 224
All Time: 3,553
