How do u fix the problem
how do i get the horn apart so i can fix the dihgram to work
Flyboy, If horn is in a vehicle, check fuse/relay first, then check that you are getting power to the horn. Since you did not state what horn needs repaired, I will post links to different speaker and vehicle horn diaphragm replacement/repair, you can always do a google or bing search for your particular year,make and model. Quite a bit of info out there. Hope this helps you out. Good luck.
https://www.youtube.com/watch?v=xZqt53N1...
https://www.youtube.com/watch?v=Tfh-OvJ1...
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 63
1 Comment
flyboy3086 horn on what device? Car, truck, moped, steamboat?
by oldturkey03
