My router suddenly quit working and won't turn on
Internet stopped and now router won't turn back on
Hi,
Are there any lights, especially the power light (is it blinking green and amber or is it solid green) showing on the router when you power it up and turn it on?
(A blinking green and amber power light indicates corrupted firmware in the router which may be rectified by reinstalling the firmware).
If so which lights are on?
If not have you got a compatible known working power adapter to see if it works with it.
(see image , select for your location - they are all 12V DC 1A output only the input varies to suit your location - make sure that the DC plug is compatible with the router as well)
If there is still no light indications at all with a new adapter then there is a problem with the power circuits in the router.
On my charter modem, all lights are on except the power light. Is it possible it is on and the light is just burnt out. Thanks
Hi @ skellsfam,
Is the modem working OK, i.e. can you access the internet or your email servers etc?
Can you access the modem's User Interface OK?
If the answer to both of the above is yes then there is a good chance that the modem's power light is faulty, possibly due to a bad connection to the light somewhere in the modem, as it is unusual for LED lights to fail. (although it can happen).
What is the model number of your modem?
If the answer to the above is no, it may be that the modem is locked up somehow, if so try resetting it by operating the reset button which on most modems is located under a pinhole in the back of the modem case. (don't know your modem so I'm only guessing it is the same)
If it resets OK you'll have to re enter all your ISP relevant settings again
@jayeff none of my router lights are on at all randomly earlier this afternoon the WiFi symbol disappeared from my phone so I went to the living room just to see if I had to the usual reset process but instead I looked at my router and realized it wasn’t even showing the power symbol I’ve called support and they seem to be no help do u have a solution by any chance
Hi @Shane Dubois,
What is the make and model number of your router if not a Netgear WGR614v9?
Have you checked that the power outlet to which the router is connected is OK?
Have you got another compatible power adapter that you can try to see if that works?
Hii ,in my router only power light or the name of my router is not showing in my system or in my phone even none of the light is working except power light.so,please help me..THANKS
Netgear is a company that manufactures and sells networking products. They are one of the most popular router brands in the world.
Netgear routers are known for their reliability, speed, and security. They have been around for over 20 years and have been providing quality products to their customers.
The Netgear R7000P is a dual-band router that provides excellent coverage in the home or office. It has a 1GHz dual-core processor with 512MB of RAM which makes it one of the fastest routers on the market today.
It also has four Gigabit Ethernet ports which allow you to connect wired devices such as computers, printers, NAS devices, etc., to your network at speeds up to 10x faster than Fast Ethernet connections.
How to Troubleshoot a Netgear Router That's Not Working Properly
First, you should check if the power cord is plugged in properly and if it has enough power supply. If it doesn't, then you should plug it in again and wait for some time before trying to use it again. Second, you should make sure that the internet cable is connected properly and that there are no loose connections anywhere. Third, if your Netgear router has an option for resetting the settings then you should try this option too because sometimes this may fix the problem with your router.
The reset button is located on the back of the router. To reset your router, press and hold the Reset button for 10 seconds.
If you are unable to locate the Reset button, please contact Netgear Support.
The reset button on the back of your router is a quick and easy way to restore it to its factory default settings.
Press and hold the Reset button for at least 10 seconds. The power light will start blinking. Once it starts blinking, release the Reset button. Wait until the power light stops blinking before you continue.
To complete the process, unplug your router from power for about 30 seconds and then plug it back in.
My wireless router has no lights it is Netgear GS105PE
When you are unable to access the internet through your Netgear wifi and getting a solution orange wifi light. It shows the issues with your network or router settings. here, in this blog, I am sharing the steps to get your internet light problem resolved.
1. Check the cable connection between router and modem; make sure your modem is able to acknowledge the router.
2. Router or computer settings are invalid; you must be entering the wrong wifi name or password, that's why you can't identify the network name or password.
3. Let’s power cycle the router and modem for a while, and then try to reaccess the network. Let’s see if it is allowing you to access the network now or not?
4. Let’s update the mac cloning and then retry to access the network. let’s see what do you see there now.
5. If you are still getting the orange lithg on your access point, you should reset it and configure it once again to make it working properly.
After resetting, I showed that the wifi light isn't glowing. Blocked
Hi i have a ZTE rooter. My rooter doesn't want to reboot and also doesn't want to connect to my phone after loadshedding yesterday. When i reset it, al the blue lights is still on and doesn't change or go of. When i log in, on the operater bar is just n red x and also on the connection status bar. It's just gives me HSPA and not LTE to connect and it doesn't want to connect to HSPA ?
Double check power cord at wall and at router. Locate the router power button and make sure it’s in the on position. If the router piggy-backs off another router unplug both routers and power up routers.
Past 24 Hours: 31
Past 7 Days: 225
Past 30 Days: 1,056
All Time: 237,747
9 Comments
Is it plugged into an outlet controlled by a switch? Maybe the switch is in the off position.
by Deleted
I had the same issue
by ludochat
Rooter gets too hot when charging or it's being used is it ok? It still new it doesn't have a month.
by Neo
One Plug Off and Plug On it
by Shreya Mathur
Well my light was on. The computer said no internet connection. I held the light control on until it went off and now it wont turn back on. I only have one button i can push on the netgear
by K Ewell
Show 4 more comments
