Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
204 Questions View all
Can't resolve the deadly 3 beeps on startup
Hello everyone,
I have a Mac Mini Unibody (mid 2011) which doesn't startup anymore. It was not in use for some time and when we got it out again it gave the 3 beep signal which would indicate my RAM does not pass a data integrity check. But my RAM does work in my other Mac which uses the same type of RAM.
I have searched for the ultimate solution on different message boards and executed several suggestions made there. I have done the following:
  • I have tried to reset the PRAM, but no succes.
  • I have hold down D during startup, but no succes.
  • I have checked the Logic board, but I can't find anything loose or broken.
  • I replaced the thermal past on the heatsink.
  • I cleaned my Mac with compressed air, but no change.
My question: Is there anything else I can try before putting the logic board in the oven? As this will be my last and final step.
Hope you have some suggestions!
Ditta
2 Comments
After some research I found that three beeps mean "No RAM banks passed memory testing", have you insured that all RAM cards are properly seated, and are in working order?
by
Yes, I have switched them around. I have used new ram cards (which are now in my iMac working just fine). I have reseated them, and tried both banks separate.
So as i mentioned, I don't think it is the RAM cards or the way they are seated.
by
Add a comment
1 Answer
Chosen Solution
What speed are the RAM modules?
Your Mac mini might not support modules you have. I would try 1333 MHz modules then see if you have any luck with them.
Score 3
1 Comment:
Mid '11 Mac mini specs: Mac mini 2.7 GHz i7 (Mid-2011)
Requires as a minimum: 1333 MHz PC3-10600 DDR3 SO-DIMMs.
by
Add a comment
Add your answer
Jedidja will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 960
