Why logic board chimes when pin is touched with probe?
Hello Guys,
Maybe one of you can help with this unusually weird problem I have with my 820-2330 logic board. The board powers on, but won't chime or boot until I touch a couple of specific pins on chip U8900. This is what happens exactly; when the board is powered on and I touch pins VO or OCSET on U8900 the board then chimes and boots normally. It is driving me crazy trying to figure this one out. At first I replaced U8900, then I replaced both FETS, then I replaced the Critical caps after the inductor all to no avail. Any help would be appreciated.
Thanks,
Roger
Add a comment
1 Answer
Look for an open trace or bad component attached to one or both of the pins you mentioned. If an input pin is not connected, touching it with a logic or scope probe connects it to ground through the probe circuit, thereby giving it a logic low (“0”)signal.
Add a comment
Add your answer
Roger will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 54
