Is my phone's microUSB port repairable?
Hello guys, I am a new member here.
( I used to refer some of the guides but only registered recently )
So I have this phone
Recently I damaged it's microUSB port
As you can see the black protruding part has broken and the copper bars are exposed
Hence, I cannot charge my device/connect it to PC.
It died today due to low charge and I cannot therefore turn on the device. The phone is my daily driver and I cannot do without it, it also has imp data. It is also rooted and bootloader unlocked with custom ROM and recovery
I think that only the microUSB port has been damaged and there are no complaints ( short circuit ) as
Since video is broken Youtube link
The notification/charging LED lights up red to indicate too low charge
I am not good at soldering so I am planning to go to local repair shop, so my question is can they fix it ? Help and advice needed ?
1 Comment
Since video is broken YouTube link
https://youtu.be/MuZPD-kc4Pc
by
Add a comment
1 Answer
Most Helpful Answer
Should be a pretty simple repair. Charge port replacements are not complicated. I would call ahead to make sure they had the part though.
Score 1
3 Comments:
Thanks for the info :)
I am still worried though that the phone battery ( li - ion ) may go to sleep mode ( low-power state ) and battery replacement may be needed If I don't fix it quickly. I can only give it to service centre tomorrow as today is a national holiday. Will the battery be completely dead by then ?
by
Probably but it should be fine.
by
Thanks, i am going to the service centre today morning :)
by
Add a comment
Add your answer
NCorp will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 200
