A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure.
120 Questions View all
Why does it not fill with water?
it wont let any water in
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
If it has never worked the spigot values may not be open.
If it has worked in the past, and no one has shut the values off and the water is running in the rest of the house, see the causes below:
Cause 1
Water Inlet Valve
The water inlet valve opens to allow water to enter the washing machine. If the water inlet valve is defective, the wash may fill slowly or not fill at all. The water inlet valve requires sufficient water pressure to function properly. First, check the water pressure to determine that it is adequate. If the water pressure is adequate, try cleaning the screens inside the water inlet valve hose connection ports. If the washer still fills slowly, replace the water inlet valve.
Cause 2
Low Water Pressure from House Supply
The home water pressure might be too low. The water inlet valve requires at least 20 psi to function properly. Check the water pressure to the valve to determine if it is sufficient.
Score 1
Add a comment
Add your answer
bawolf12 will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 61
Past 30 Days: 325
All Time: 2,083
