No Power after soaking Logic Board
Hi Everyone,
New to this. My daughter recently spilled some water on her MacBook. Removed hard drive and it would just come up with a question mark. I put hard drive back in and was able to run diagnostics. It came back with an error, "4SNS/1/40000001-VPOR-4.956". I guess the issue is a sensor for Voltage on the power bus. So, I soaked the logic board in isopropyl alcohol and let it dry overnight. I put it back together and now it will not power up at all. Serial number is "C1ML68VQDTY3". I also did a search for an internal fuse, but, so far have had no luck.
Am I looking at a new Logic Board? Should I even try that?
Thanks for any suggestions....
Update (09/14/2016)
2 Comments
I have an update. I checked the power on the magsafe adapter (?) pictured. I get no voltage between 1 and 2, 2 and 5, 4 and 1, 4 and 5. Both 1 and 5 and 2 and 4 have continuity. When I connect it to power I have no continuity between 6 and 7. I am thinking (hoping) that 6 and 7 may be a fuse? If so I think a new one is about $15 on Amazon. Does this look crazy or am I possibly on the right path?
by Pat
I cannot figure out how to post an image. As soon as I do I will post it.
by Pat
