Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1398 Questions View all
Can I run Final Cut Pro X?
Hello,
I'm going to get a 2.1 ghz C2D MacBook (white) with a broken keyboard for 40$. I can just use it with an external keyboard. But, the main reason I want a Mac is to run Final Cut Pro X. Obviously I'm not going to be editing 1080p video, but just to tinker with and figure out how to use. I have a copy of Final Cut Pro X 10.0.8 that I tested on another Mac. So, would this MacBook run Final Cut Pro? Or should I just get a Mac mini and upgrade the CPU?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Sadly, no.
The issue here is systems hardware, a full 64bit platform is required to run Final Cut Pro X.
You'll need a i5 or i7 CPU based system running Mavericks or newer.
Score 1
Comments:
I thought this was 64-bit?
by
Here's the specs for your system: MacBook Core 2 Duo. Jump down to Pre-installed MacOS, review the comment on the CPU & EFI details.
by
@danj That's not the right one though, that's a 2.0ghz MacBook 2,1 and mine is a 2.1ghz MacBook 4,1.
Also, why won't this run el captain/Yosemite/Sierra? It has a 64bit EFI and CPU
by
OK here's the corrected models specs: MacBook 13" 2.1 GHz Core 2 Duo
You still face the limits of the hardware and what OS-X the system can support. Sorry ;-{
by
Add a comment
isn't the c2d in a macbook pro 2008 and macbook 2010 or newer 64 bit? I know my old mbp was a 64 bit as it ran el capitain. As well as the macbook white unibody from 2010 with a 2.4 ghz cpu that runs sierra.
ooh sorry didn't know we were talking about the macbook in the photo :I
Add a comment
Add your answer
Gigabit87898 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 68
All Time: 1,069
