"Mini" USB port recognition
Hi:
I'm hoping there are some folks here who really know about this particular model (3300a). I have a plethora of questions concerning this phone. But, first I'll just proceed with this one. According to the users manual, the charging port is also a mini USB port! If it is indeed a mini USB port, once I use a USB pendrive in that port, where is it(the pendrive) supposed to show up within the phone? It does NOT display anywhere in audio or the VLC "player" I've installed. Anyone got any ideas?
THANX:
Rick
bold text
2 Comments
Hi, First I know nothing about your device, but if you have a 'file manager' type app plug in your flashdrive and use the file manager app to see if it shows up there and what it is called. Ensure that your flashdrive is formatted in FAT32 not NTFS.
If it doesn't show up you may have to purchase a compatible OTG (On the Go) cable to connect the port to your pendrive.
by jayeff
Thankx jayeff
Appreciate your response and your suggestion is duly noted. Always good to hear from a friend from "down under"! In regards to "If it doesn't show up you may have to purchase a compatible OTG (On the Go) cable to connect the port to your pendrive." I have an adapter that the pendrive plugs into, then you plug the adapter into the "mini USB port/charging port. Isn't your "cable" and this "adapter" one-in-the-same?
Regards:
Rick
by Rick
