Repair guides and troubleshooting information for microwave ovens.
756 Questions View all
Capacitor keeps failing, Whirpool microwave doesn't heat
I have changed the capacitor 2 times but after a few days of heating, the microwave stops heating.
Any idea what could be going wrong? The diode tested fine. And if I put a new capacitor, it works for few days - so I guess that rules out Magnetron and other switches n stuff. So a faulty circuit board probably?
Has anyone had this problem?
Score 1
Add a comment
1 Answer
Most Helpful Answer
mrchief,
Just because it works again after a capacitor replacement does not mean the magnetron isn't failing. It could possibly be that the magnetron is burned out bad enough that you are over-driving the capacitor to blow out.
There should be more than one cap in the power circuit for the magnetron driver circuit. It's a turned circuit, so check out an iductor loops in there as well for visible damage to their insulations.
Even with a schematic and some thorough circuit testing, finding an impedance/reactance mismatch would be pretty difficult. Your hint might be that the cap is either getting overvolted, or draw much too much current.
Hope that helps, best of luck
Score 1
Add a comment
Add your answer
mrchief will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 15
All Time: 925
