Stuck on Apple Logo but battery low
I have already been through this thread
Stuck in continuous apple logo loop, turns off when cable removed?
Unfortunately, my situation is compounded by the fact that my phone has no power left. Thats how it started in fact. So you plug in the phone and it shows the battery icon but only for about 5 seconds. Then it immediately tries to boot despite not having enough power. So it goes back to charging mode of around 5 seconds and repeats. It seems its trying to boot without enough power.
So even if I try the above steps, it just goes back to battery icon mode for 5 seconds and never even tries to boot up.
Any thoughts?
3 Comments
If the charging port pins don't look damaged, clean the charging port if the charging cable does not plug in fully. Otherwise you probably need the battery replaced.
by Ben
Its trying to boot before the battery gets sufficiently charged.
by stuart
Are all of the components near the battery connector on the logic board there? If one of them are missing that probably is what is causing the problem as it's stopping it from reading the battery correctly.
by Ben
