Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
354 Questions View all
Rev.b 9400m Logic Board in rev.a MacBook Air?
Has anyone successfully done this? From what I can see, the only real difference is the hard drive connector (SATA) and a slightly modified heatsink.
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
There are a few differences to account for:
  • The multitouch cable connector on the upper case has been relocated in the Rev.b machines, which makes connection difficult.
  • The black shielding on the lower case is slightly different. This may or may not affect compatibility.
  • The audio board is not compatible between models. You would need the correct audio board and cable for the appropriate logic board.
  • The hard drive connector, as you noted, is different and must be worked around.
  • The fan/heat sink are 2 separate pieces in Rev.b.
  • The airport/bluetooth cable is slightly different as well.
I haven't actually performed the swap; these are just the physical differences.
Good luck!
Score 5
Comments:
Re. multitouch cable.. Difficult to the point of it being impossible?
Also, seems strange the audio board would not be compataible, wouldn't it be software (ie OSX) that determines that?
by
+ good answer
by
Add a comment
Add your answer
Tom will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 2,104
