Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
291 Questions View all
With my iMac internal HD unplugged, will HD temp sensors go crazy?
iMac 21" 2011 mid2011
I plan to boot my iMac 21" 2011 mid2011 solely from a external SSD via Thunderbolt and I do not want the internal spinning HD powered on, I have no use for it.
If I open up my iMac and unplug the internal HD sata and power cable from drive and close up the iMac, will the internal HD temp sensors go crazy and run the fans up high?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Is the original drive still in it with the temperature sensor attached? If so it should work by disconnection the main HD cables.
Score 2
Comments:
Yes, although, there is no discrete temperature sensor attached to the internal HD. The only 2 cables that plug into the internal HD are the sata cable and power cable.
by
Add a comment
Add your answer
handsonmac will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 68
