Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
iPhone 6 shows "not certified cable" and isn't charging
I am currently repairing a phone which I though had a lightning connector damage, as it showed "this cable or accessory is not certified and may not work reliably with this iphone" with all chargers and cables (i tried 3 different cables which work perfectly with other iphones). I tried plugging in another battery as the original one was completely empty, I can boot the phone but it still brings up this message everytime I connect the charger. I replaced the lightning flex as well but it still shows the same error message. Already tried cleaning the port but still nothing.
I think I've tried everything but I can't get the phone to charge.
Does someone have an idea?
2 Comments
Can you still use the iPhone or is it a hard stop? If the customer will let you I'd backup the phone and try wiping it and doing a clean iOS install.
by
With another battery I can still use it but the battery only had a few percent left so I wasn't able to do a backup. I could only wipe it via settings because I can't connect it to iTunes...
by
Add a comment
Chosen Solution
Board issue, start with the U2 IC.
Score 3
Add a comment
Try cleaning the charge port and reinstalling cable, charge port could be defective and in need of replacement.
Score 1
1 Comment:
I already replaced the charg port and it still shows the same message.
by
Add a comment
Add your answer
ppalfinger will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 107
